Sharptools and Alexa integrations not working correctly
Woke up this am, tried to run a rule via alexa and nothing happened.
tried to run the same rule via a sharptools button and same result.
Alexa will control bulbs connected via Hue integration but nothing else (eg, a zigbee bulb).
Is this connected to the Authorization issues that Hubitat has been having?
Is less likely to be related to authorization process, and more likely that your hub is no longer connected to the cloud. I would check your network set-up and/or reboot the hub/router to see if that solves the problem.
roger that, appears that was the issue, the HE hub was on line but still needed to reboot.
thanks
