When I hit initialize, it seems to go on and on in kinda like a loop.
Summary
dev:7752019-12-08 08:07:28.906 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.867 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.804 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.783 am debugSharpAquos - rawSocket request = [IAVD? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:28.779 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.728 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: Connections could not be acquired from the underlying database! on line 93 (socketStatus)
dev:7752019-12-08 08:07:28.678 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.604 am debugSharpAquos - rawSocket request = [VOLM? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:28.570 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.448 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.324 am debugSharpAquos - rawSocket request = [IAVD? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:28.319 am errororg.quartz.JobPersistenceException: Failed to obtain DB connection from data source 'myDS': java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 100 (socketStatus)
dev:7752019-12-08 08:07:28.254 am errorjava.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (socketStatus)
dev:7752019-12-08 08:07:28.205 am errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (socketStatus)
dev:7752019-12-08 08:07:28.162 am debugSharpAquos - rawSocket request = [MUTE? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:28.136 am errorjava.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 80 (socketStatus)
dev:7752019-12-08 08:07:28.032 am debugSharpAquos - rawSocket request = [VOLM? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:28.026 am errorjava.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 70 (socketStatus)
dev:7752019-12-08 08:07:28.003 am debugSharpAquos - Initialize error. TV IP Address not set
dev:7752019-12-08 08:07:27.988 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:27.985 am debugSharpAquos - socketStatus - UNHANDLED socket status [send error: Socket closed]
dev:7752019-12-08 08:07:27.961 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:27.929 am debugSharpAquos - rawSocket request = [POWR? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.910 am debugSharpAquos - socketStatus - received [send error: Socket closed]
dev:7752019-12-08 08:07:27.873 am debugSharpAquos - getDeviceState()
dev:7752019-12-08 08:07:27.769 am debugSharpAquos - rawSocket request = [MUTE? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.753 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:27.742 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:27.737 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:27.710 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:27.696 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:27.692 am debugSharpAquos - socketStatus - received [send error: Broken pipe (Write failed)]
dev:7752019-12-08 08:07:27.617 am debugSharpAquos - rawSocket request = [RSPW2 ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.613 am debugSharpAquos - Initialize error. TV IP Address not set
dev:7752019-12-08 08:07:27.609 am debugSharpAquos - initialize - Poll Rate set to every 5 minutes
dev:7752019-12-08 08:07:27.603 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:27.600 am debugSharpAquos - socketStatus - received [send error: Broken pipe (Write failed)]
dev:7752019-12-08 08:07:27.586 am debugSharpAquos - rawSocket request = [IAVD? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.550 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:27.511 am debugSharpAquos - rawSocket request = [POWR? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.505 am debugSharpAquos - getDeviceState()
dev:7752019-12-08 08:07:27.424 am debugSharpAquos - rawSocket request = [IAVD? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.399 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:27.391 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:27.384 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:27.315 am debugSharpAquos - rawSocket request = [VOLM? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.261 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:27.248 am debugSharpAquos - rawSocket request = [RSPW2 ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.243 am debugSharpAquos - initialize - Poll Rate set to every 5 minutes
dev:7752019-12-08 08:07:27.218 am debugSharpAquos - socketStatus - UNHANDLED socket status [send error: Socket closed]
dev:7752019-12-08 08:07:27.213 am debugSharpAquos - socketStatus - received [send error: Socket closed]
dev:7752019-12-08 08:07:27.170 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:27.164 am debugSharpAquos - rawSocket request = [VOLM? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.120 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:27.111 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:27.107 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:27.062 am debugSharpAquos - rawSocket request = [MUTE? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:27.057 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:26.998 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:26.992 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:26.975 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:26.971 am debugSharpAquos - socketStatus - received [send error: Broken pipe (Write failed)]
dev:7752019-12-08 08:07:26.967 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:26.962 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:26.945 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:26.911 am debugSharpAquos - rawSocket request = [MUTE? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:26.907 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:26.797 am debugSharpAquos - rawSocket request = [POWR? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:26.791 am debugSharpAquos - getDeviceState()
dev:7752019-12-08 08:07:26.718 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:26.707 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:26.700 am debugSharpAquos - socketStatus - received [send error: Broken pipe (Write failed)]
dev:7752019-12-08 08:07:26.673 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:26.649 am debugSharpAquos - rawSocket request = [POWR? ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:26.642 am debugSharpAquos - getDeviceState()
dev:7752019-12-08 08:07:26.633 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:26.616 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:26.612 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:26.535 am debugSharpAquos - rawSocket request = [RSPW2 ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:26.529 am debugSharpAquos - initialize - Poll Rate set to every 5 minutes
dev:7752019-12-08 08:07:26.391 am debugSharpAquos - rawSocket request = [RSPW2 ] to 192.168.254.205:10002
dev:7752019-12-08 08:07:26.383 am debugSharpAquos - initialize - Poll Rate set to every 5 minutes
dev:7752019-12-08 08:07:26.132 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:26.122 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:26.118 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:26.109 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:26.023 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:26.013 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:25.992 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:25.987 am debugSharpAquos - socketStatus - UNHANDLED socket status [send error: Socket closed]
dev:7752019-12-08 08:07:25.984 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:25.980 am debugSharpAquos - socketStatus - received [send error: Socket closed]
dev:7752019-12-08 08:07:25.976 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:25.963 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:25.955 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:25.951 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:25.914 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:25.664 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
dev:7752019-12-08 08:07:25.627 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:25.620 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:25.616 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:25.591 am debugSharpAquos - initialize - IP: 192.168.254.205 PORT: 10002 USER: null PASS: null Poll Rate: 5
dev:7752019-12-08 08:07:25.581 am debugSharpAquos - initialize - Driver v0.11
dev:7752019-12-08 08:07:25.577 am debugSharpAquos - socketStatus - received [receive error: Stream closed.]
dev:7752019-12-08 08:07:25.463 am debugSharpAquos - initialize - Set DNI = [9CC7D1ED5F5F]
and a lot lot more......
