I use this Wyze Sense integration that is Telnet and I have that running along with Lutron Hub integration. The developer might be able to give you some pointers.
Note 2020-09: I no longer have Hubitat and have moved onto another platform. Unless forked, there will no longer be any updates to the code base.
So I posted a teaser a few days ago on Twitter and /r/hubitat that I've been working on a WyzeSense device handler -- well here it is!
The system relies on the work of the WyzeSensePy project by HclX and uses a Raspberry Pi to act as a host for the WyzeSense bridge device. Instructions are on the GitHub page as to how you need to setup and configur…
