As i run all automation on Node Red, and just use hubitat to pair devices which is, i guess, minimal compared to some folks, i cant see what would cause such a high cpu load.
Clicking on the links in the error message to go to device stats, resloves to a 404 error page!
Ive looked through logs, but can really see what could be the culprit
Any suggestions
Cheers
Maybe start by telling us what hub firmware you are on? There were some changes in recent updates that I believe were supposed to help this.
Is this a C5, C7?
Do you have Zigbee, Zwave, LAN devices, cloud integrations?
The link in that message is supposed to take you to the app stats or device stats page. When you were in logs, did you tab over and take a look at those stats? It could be a device and not an app causing this.
As the zigbee network was down, i needed to restart the hub.
The hub hung during restart and did not recover. Only way to bring it back to life was unplugging power, and plugging back in
Before trying to restart, i took this grab from the devices page
It seems high, but ive never looked at it in the past, so couldnt know either way.
I have had this device running without change for 12mths odd and no cpu issues until now
