Setup
I can’t get my c-3 hub to pair with my Honeywell thermostat. I’m a newbie and the hub is new just out of the box. I could not “exclude” from the thermostat, so I did the factory reset on the thermostat and I’ve tried several times to “include” but it fails every time.
'Say What' GIF by BEARISH
Can you double-check your hub model? This model is 8 years old, so even if it were "new" in box, that whole phrase takes on a different meaning if that is indeed the case. :slight_smile:
If it is, I'd start by making sure you have a USB Z-Wave dongle plugged in, such as the ZCOMBO that came with the North American version or something appropriate for another region -- and also that your device is a Z-Wave device in the first place (true, of course, for any model of hub). What specific model of thermostat do you have, and why were you not able to do an exclusion? That is a mandatory feature on all Z-Wave devices.
I’m sorry, you’re right, it’s a c-8 hub.
Thermostat is a Honeywell TH6320ZW2003
Both good!
What happens when you try an exclusion or inclusion? Keeping “Logs” open in another window or tab may provide additional clues if you don’t see anything else on screen.
Thanks! I excluded everything and rebooted the hub and started ths setup procedure from scratch and got the thermostat paired, but, I’ll be darned if I can get my Kwikset 460126VHC paired. I can see it sort of, in the settings/z-wave details, but as I scroll right, the name is not highlighted like the thermostat is.
Please show your zwave details page as a screen grab.
I tried to do that but it wouldn’t allow me to do so. Said something about “media not allowed“, or something to that effect. I used the little square icon that shows at the lower right hand corner of their message box… across from the reply button and the trash can button. How do I post a screen shot. This is my first time using this forum.
add yourself to the Owner group in your profile.
You need to be a member of the Owners group to post images. I have added you to the Owners group, so you can do so.
