Newbie with Hubitat that is familiar with smarthings and basic DIY smart home networking.
I purchased the Sonoff SNZB-04 contact sensor and want to set it up with Hubitat. Do I also need a Sonoff bridge hub? Or should Hubitat be able to serve the same purpose as the Sonoff bridge?
Adding the device to Hubitat without the Sonoff bridge hasn't worked so far.
Thank you. I got it to work (no Sonoff bridge required).
Related question if you know - to receive push notifications in the mobile app, do I set up a rule in Rule Machine? I see the open/close activity in the log, but I didn't automatically receive a push notification in the Hubitat app about activity.
You can get notifications through rule machine and there's also a native app called notifications. Not sure if this particular device will be exposed in the notifications app.
While this driver will probably still work, Hubitat has a built-in driver for this now, "Sonoff Zigbee Contact Sensor," so it will work natively. (I'd probably recommend this given that there is unlikely to be more development on the linked community driver.) As a side note, pairing should work with or without a matching driver--if nothing else, it will pair as "Device," and you can figure that out later. So, if that doesn't work, something else is probably wrong. (If it's anything like my luck with these devices, it's because when I think I'm pressing/holding the button, I'm not doing it the right way...)
