Setting up a lighting transition and getting error
I have repeated this error using Room Lighting.
Create New Rule and select 2 RGB devices
Select Means to Activate as a Transition over 30 seconds every 5 seconds
Select Setup Lighting Periods and go to select color and pick green and BOOM you get:
Log shows:
You can never get back into it at that point and must delete it.
I just followed those steps with no problem. What kind of RGB device?
Also, try something ever simpler: forget the transition, just see if you can set the color to green on the main page.
Inovelli LZW-45
What release are you on? Please update to 2.3.4.122 if you haven't.
I am on 122.
When you go to pick green, which of the two tables are you doing that on? Show the tables before you do this.
Click either where the mouse is there or the box next to it. Then I pick Green and as soon as I select green it errors.
The driver I have selected for the Green and Red device is Generic Component RGB. Should it be something else?
I think I know what is causing this, and it's clearly getting bad values from the devices. Show the Current States of those devices from their device page.
Just shows Switch Off:
It does turn on and off on both the red and green device just fine.
Clearly, that device does not have its attributes set properly, and that is the cause of this error.
Not sure what I can to do fix it. Oh well not that big a deal.
Try a different driver.
That was the only one giving me color choices out of:
Generic Component RGBW
Generic Component RGBW Light Effects
Anyone else out there have any luck with color transitions on an Inovelli LZW-45 light strip?
This has nothing to do with transitions. It has to do with the device not having its attributes set. You need to solve the device problem first. I have no clue, not my area of knowledge.
Ya me either and the actual Green and Red Sub-Device turn on and off as green and red just fine. Like I said not that big a deal. I'll just not worry about it. Thanks for taking a look.
Without ever setting any attribute? That's not right. Room Lights uses device.currentLevel, device.currentHue, device.currentSaturation to function. Without those, it can't do its thing, and certainly couldn't run a transition.
Meanwhile, I know how to prevent the error from blowing up the app instance. Although fixing it wouldn't be enough for a transition to work right.
Dunno. I know if I go to the driver for Green click on green it comes on in green and the same for red. I'm more lost than you on this. I am trying something if it works I'll be back.
