Hi, I am trying to setup my hubitat to notify me when the garage door sensor detects that the door was left open at night (I have been trying to use the sunset +30min trigger) but it says ANY at the stop instead of AND, is there a way to change this? Basically I want to only be notified if it's night, and the door has been left open for more than 10 minutes. Is there a way to do this?
Thanks in advance!
First off, WELCOME!!!
It's definitely doable but you cannot have an AND in the triggers. If you were able to put an AND, the 2 triggers would have to fire simultaneously.
Try this instead. I think it will do what you are requesting.
EDIT: Sorry, I forgot that you will also have to address when the door closes in your IF-then statement so that it will cancel the sending of the notification. It's late and I am tired .
