Setting outlet flash rate
I have a SONOFF model: S31 Lite zb that I want to set the flash rate prior to turning on flash.
The values on the device page are: No selection, 750ms, 1s, 2s and 5s.
Is there a way I can set flash rate to one of these values prior to turning on flash?
No, this is a preference that must be set once, then it will be used whenever you use the command.
However, all it does is repeatedly turn the device on and off (nothing special, i.e.., it's not a built-in device feature). You can create the same outcome on your own in a number of ways and customize it however you want, for example, with a Rule that does whatever you want.
