I've replaced every single bulb in the house with Sengled Element Color Plus bulbs. I just started testing changing them via rules rather than setting them via voice (Alexa) and noticed some unexpected behavior. The only changes I've been doing so far (via voice) was setting the level and shifting between white colors (i.e. cool white, white, warm white) or using colors via HSM.
Any of the light fixtures that have multiple bulbs have been setup into groups in 'Groups and Scenes' which has worked well in Alexa. But I thought that using the groups might be the cause of the unexpected behavior, so I did a little testing tonight to see if that was correct. I also needed to know what the difference between Set and Toggle actually were since I haven't found it in the documentation or the community after searching.
Starting with the bulb at 20% and warm white and ON
As a group
Set color: Livingroom Light Group ->Blue ->Level: 100
The color and level changes as expected
Toggle color: Livingroom Light Group ->Blue ->Level: 100
Turns OFF bulb! Turning on goes back to the prior setting (warm white at 20%).
Single bulb
Set color: Livingroom Light 1 ->Blue ->Level: 100
Toggle color: Livingroom Light 1 ->Blue ->Level: 100
Starting with the bulb at 20% and warm white and OFF
As a group
Turns the bulb ON with the color and level changes as expected
Single bulb
Bulb stays OFF but when turned on is at the expected color and level
Is this the way that Set and Toggle for color bulbs should be working?
