Set Variable missing?
probably my error, but i can't seem to get 'Set Variable' to appear in the actions list. i've tried making fresh rules with different device type triggers thinking maybe that would make a difference. still nothing. any ideas?
Running 2.3.0.124 and while this may not be terribly helpful, "Set Variable" simply appears when using the appropriate action for a new rule:
A bit speculative, but have you created a global variable ahead of the rule? That item may only be put in the list if there's actually a variable there to be set.
Rule machine only displays the available functionality. As an example, if you don’t have water sensors, the related options will not show. As @ian3 indicates, it is important that you define a hub variable from the settings menu, or a local variable from the bottom of the main page of the rule you are creating. Once created, the option should appear.
Please let us know if you run into difficulties, and welcome to the community!
Appreciate the speculation. Everything is showing up as expected now.
Seems I need to brush up on global variables.
