When I created a Rule that sets temperature and level, and ran that rule, nothing happened. When I removed that action and instead set color and level, it worked.
Considering I use the color bulbs to trigger a color based on HSM status, I'd like to reset this bulb back to the default temperature, but using the built in warm white and soft white colors are too blue for my liking besides just being colors and thus are not as bright when setting temp - go figure.
@at9 How are you setting temp? Is there are a better way of doing what I'm doing above.
Life savor. A simple driver change, I never would have known.
I did purchase some Segland bulbs to compare since I wasn't sure if this was able to be corrected.
So my last question. If i set the bulb to a color to indicate HSM status and shut off after, whats the best way to reset the bulb setting to temperature so when it's turned back on it's the correct temp? I wrote an RM rule to do a auto turn on based on time and set the temp, but what about if manually turned one?
You could have a rule triggered by the light changing due to HSM status and use a wait for event of the light turning on so next time it will turn on with the colour and then straightaway change back to the temperature.
Here is a rule I already had setup. It would change purple to indicate Status, and then turns off. I originally had it switch back to temperature before turning off, but since one of these are in our bedroom, I was trying to avoid a bright light turning on (reseting temperature and level) before turning off in case someone was sleeping. Ideally I could reset back to temperature after it turns off, but I'm not sure thats possible.
I must be a dummy to this. I tried add a set temperature to the RM, but all it did was change the intensity of my purple color. It's like if I set color, I'm not succsefully getting it back to temperature values....
I was thinking this.
I needed the delay in between the actions as there is a 1 second delay on the sate of my yeelight updating and you can't add a delay to a wait.
Between the driver and the wait action, it fit the need. yeelight actually has a smoother transition than the sengled, just more pleasing and settle. Thanks @at9 for your help. A big breakthrough on something that helps alot.
The only thing I like is the Sengled as least function without the need of an app so feel more native and local.
