Hi,
I don’t know if I m at the right place but I would like to propose a feature in webcore. I use url features with args to update some variable, global or local… and if you have multiple variable to manage that way, you need a block of code for each one like:
If args.temp is not empty then set @temp = args.temp
But it would be nice to be able to match args with the variable name…so with one block we could update any variable with 2 args (one for variable name and other for value)
If args.name is not empty then set @args.name = args.value
It could be a function in the drop down menu when editing the piston or something… so it could check for matching variable name and if no match do nothing or just built the block with some checkup…
Just to specify that by propose I meant request.. but pretty sure it would be not to complicated to add in the webcore code… if someone know who manage the webcore update in Hubitat it would be nice to make him know about it or redirect me to the right place to ask…
I think andy is not on it anymore so not sure if it’s still updated…
I have the built in install… I could reinstall it but not sure what to do to install your things… do you have any information on that? The function should be added to code somewhere…? Thanks!
and to be sur it does the right thing, as in your print screen, could I make it like that:
variable (btest = aint) so
set variable {btest.value} = any value
would set the variable aint to the desired value ? Or if I could do an expression like: {setVariable(btest.value,10)} so the expression itself would set aint =10 ?
Thanks again, and how long it could take for the changes to be on the built in version?
thanks, I have a last question, when I select the 'set variable' option, I m forced to select the variable to update so with your function, how would it works ? Is there a new menu or something to be able to use expression in the variable menu section?
yes, I corect it I meant Variable (the menu where the check mark is) but if as you said your program allow to use expression in this menu...its exactly what I need I think! Cant wait to see if it ll works as expected!
Thanks again for your work, I think a lot of users was waiting for it!
Hi, The update is done and it seems to work, I only have a question on how to use it. I mean, would it be more simple if the "variable" menu get the expression to choose and set the variable with your formula? Because we are forced to choose a variable to update and then in the other menu with the expression we use the formula... As I said it works well but its hard to follow visually (it said update variable X and actually with the formula it gonna be any others...)
Thanks for your works again! It works well and will save me a lot of code line!
Yes, that works well as the variable specified in the first step still unchanged and the one called in the expression in the next step is updated! I not a dev so not aware of those restriction in code...Well its a little workaround but working so thanks again! That was one of the things that was needed in webcore to be efficient!
