Please make it possible to set dimmer to a local variable. At the moment only numbers are accepted.
Thank you
Thank you
You can - surround the variable name with "%" (like "%Variable%") in the "To This Level" field.
I have noticed that you have to "Update Rule" after creating the variable before that field will recognize it.
