Hello All, I'm new to Hubitat and I'm trying to set a bulb color based on when other bulbs are set to a color. Simply put, I have rgbww leds all over the kitchen except my puck lights can only do rgbw (warm white only, not cool white). So when all the other lights are set to cool white with my remote my pucks turn off since they don't have that 5th color lead to connect. So I'd like them to turn blue when all the others turn cool white. All the apps I found just have a trigger of on/off but not on a color selection. Any help would be appreciated.
Try the inbuilt app called Mirror, then add a New Device Mirror.
Hey Mike, I tried Mirror but it seems to just tell the slave device to "mirror" exactly what the master device does and not able to select a different color than the master.
right, I thought that's what you wanted.
I think you're going to need to do this with the scene component of groups and scenes.
Without knowing what your controllers are. Can you simply connect the "open" output of the puck to one of the other puck colors.
I have a Zooz RGBW controller. You can connect some or all the outputs to the same load.
You can do this in Rule Machine. Use the other lights color temperature as a trigger. When all of them are between two CTs have them trigger the other light to turn blue. I wouldn’t use an exact CT value in case the other bulbs don’t match the exact CT value.
