Set a rule to Turn a switch on ,on Reboot? Wink relay
When my wink relay resets, it boots with the switch off and my hue lights won’t work. Is there anyway to make it turn on upon reboot
I don't know anything about the Relay, but @josh would (although I don't think he uses them anymore). However, if I had smart bulbs, I would not control them with a smart switch like the relay.
I would wire the bulbs to be always on. I would wire the switch to be powered as well. And then use Rule Machine to control the lights based on the switch being on or off.
I would too, but it’s too late. I’m redoing all my outlets with smart switches in dec. I’m going to make a thread later for suggestions. Thank you
You could create a rule to periodically send a command to turn the relay on. If it's already on, it won't hurt anything as nothing will change. And if it's off from a reboot, then the command will successfully turn it back on for you. :slight_smile:
