Hi. Due to an issue with the built-in Sengled Element Color Plus driver I had to use the Advanced Zigbee RGBW Bulb driver instead. I had 24 bulbs working just fine with the Advanced Zigbee RGBW Bulb driver. I added 2 more bulbs today using the advanced driver with no issue, but when I went to install the third, the advanced driver no longer worked. I.e. I tried to change settings, or turn the bulb off or on, but nothing happens. I tried removing, re-pairing the bulb, but there was no change. Switching back to the Sengled driver fixes that, but the other issue arises.
I removed the last bulb that worked and repaired-it. The bulb no longer worked with the Advanced driver.
I then tried rebooting the hub, but that also changed nothing.
This is a screen shot with the advanced driver working:
This is a screen shot with the advanced driver not working:
Any help would be greatly appreciated!
Edit: I should add that the other bulbs that were working, still work.
