I've had a bunch of Sengled Color bulbs hooked up to hubitat for several years now, with essentially no issues. I typically switch them to be themed by holiday, white in between. Recently, I switched half of them (in a group called "Front Porch") to be orange for Halloween. Then, the fun started. There have been 3 issues.
- When I first made the change, 2 of the bulbs decided that they wouldn't come on with the schedule anymore. They are set to turn on a few minutes after sunset and go off a few minutes after sunrise.
- Now, I'm trying to change them back to white, and am unable to do so. Using the "Set Color Temperature" option changes them to a light blue-ish color.
- I changed them to a different color (doesn't matter what), then turned off the switch and turned it back on. Now, they all reset to Orange again.
This is NOT impacting the other Sengled bulbs that were not switched for Halloween. Those are also in a group on the back porch, and I can reliably turn them on/off, change color (and have it persist through a power cycle) and turn them white. All of my bulbs are currently using the Sengled Element Color Plus (legacy) driver, but I've also tried the non-legacy version and generic Zigbee RGBW drivers. No difference.
Any thoughts?
Here are some logs from the last power cycle. I turned this bulb to Yellow, flipped off the power and back on, and you can see it get reset to Orange.
dev:672022-11-10 08:10:17.359 PMinfoSengled Porch 3A color was set to Orange
dev:672022-11-10 08:10:17.355 PMinfoSengled Porch 3A hue was set to 7%
dev:672022-11-10 08:10:17.348 PMdebugdescMap:[raw:D4900103001000002012010020FE, dni:D490, endpoint:01, cluster:0300, size:10, attrId:0000, encoding:20, command:0A, value:12, clusterInt:768, attrInt:0, additionalAttrs:[[value:FE, encoding:20, attrId:0001, consumedBytes:4, attrInt:1]]]
dev:672022-11-10 08:10:17.325 PMdebugdescMap:[raw:D49001000808000020FE, dni:D490, endpoint:01, cluster:0008, size:08, attrId:0000, encoding:20, command:0A, value:FE, clusterInt:8, attrInt:0]
dev:672022-11-10 08:10:14.127 PMinfoSengled Porch 3A is on
dev:672022-11-10 08:10:14.115 PMdebugdescMap:[raw:D4900100060800001001, dni:D490, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:672022-11-10 08:10:12.746 PMinfoSengled Porch 3A is on
dev:672022-11-10 08:10:12.744 PMdebugdescMap:[raw:D4900100060800001001, dni:D490, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:672022-11-10 08:10:12.726 PMdebugdescMap:[raw:catchall: 0000 0006 00 00 0040 00 D490 00 00 0000 00 00 01FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D490, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[01, FD, FF, 04, 01, 01, 19, 00, 00]]
dev:672022-11-10 08:09:56.411 PMdebugdescMap:[raw:D4900103000808003000, dni:D490, endpoint:01, cluster:0300, size:08, attrId:0008, encoding:30, command:0A, value:00, clusterInt:768, attrInt:8]
dev:672022-11-10 08:09:56.384 PMdebugdescMap:[raw:catchall: 0104 0300 01 01 0040 00 D490 00 00 0000 0B 01 0000, profileId:0104, clusterId:0300, clusterInt:768, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:D490, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:672022-11-10 08:09:56.297 PMdebugsetHue(13)
dev:672022-11-10 08:09:56.225 PMinfoSengled Porch 3A color was set to Yellow
dev:672022-11-10 08:09:56.221 PMinfoSengled Porch 3A hue was set to 13%
