I'm seeing some very odd behavior with the new Sengled Element Color Plus driver. When I have the attribute reporting set to 1s, when I turn the bulb off, the bulb reports off but the level reads as something around 9. So, the next time I turn the bulb on, it only comes up to a level of 9 instead of 100% that it was at before. Is there something wrong with the way I have the setting set for this bulb?
Or do we ALWAYS have to issue a setLevel command instead of ON? I'm only wondering since I'm trying to work out some transitions from one color to another using the color pre-staging rather than switching directly from one color to the other, first turning the bulb off then to the new color and then back on. With the color pre-staging activated, the set color doesn't actually turn the light on, which is nice.
Also, level pre-staging....how exactly is that supposed to work? Once you issue a set level command you're supposed to then issue an on command? I'm not quite understanding what that is used for. These bulbs always fade to zero before turning off when an off is issued to them. So, when you issue a setLevel command, it always has to ramp up from zero, even with level Pre-staging off. So, I'm not really understanding how to use that feature or what it's for. I could use some wisdom from the masters.
Oh..and since I know you were working on these @mike.maxwell, I'll tag you. Any insight into the inner workings of the new Sengled drivers (without revealing anything proprietary of course) would be greatly appreciated, both for working with the bulbs and general knowledge on how all this crap works. Thanks so much!!
