Just got my hubitat and starting to add devices.
Was able to add hue bulbs to hue bridge and add them to hubitat with the integration app.
Was able to add a Hue smart button directly to hubitat.
No zigbee devices are found when searching in hubitat. After failing I tried with the sengled hub (which I'd prefer not to use) and it found the bulb ok.
I reset the bulb and tried the others, but no luck.
I see the supported devices includes the Element Classic E11-G13 and E11-G14 but not these.
Anyone get these working? Or anything I'm doing wrong? Wonder if the starter kit bulbs only work with the sengled hub or if the hue integration is messing up non-Hue bulbs?
Make sure your Hubitat Hub and Phillips Hue bridge are on different Zigbee channels (15 and 20 are good choices.). If the Sengled hub is also powered on, make sure it is not conflicting with the Zigbee networks of the other two hubs.
Thanks @ogiewon. Both were channel 20. Updated Hue bridge to 15. Still not working yet. It mentioned in hubitat that it could take 24 hours for devices to update. I'll test them again in a bit.
@tivomaniac I don't see any drivers. That would be if the device is found but not working? I'm not that far yet, just trying to get them discoverable at the moment.
I've had a couple of issues with the Sengled bulbs. Some of the Element Plus, are displaying in the repeating table despite not being repeaters. I also had trouble pairing one all together. I put it down to a bad batch of Sengled Bulbs due to no one else having problems and awaiting replacement
Tried again using a mains light instead of a lamp. Did another factory reset and it worked this time.
Sengled factory reset instructions include "A turn style lamp will not work." I guess I wasn't resetting it properly, although it was flashing after with the lamp too.
Not sure if it was the reason for it working or if it was a coincidence and something else fixed it...
