i have 2 hubs installed with hub mess on and all devices shared
sengled bulb installed on hub2 works fine on,off,color change etc.
the problem is on hub1 i can only turn bulb on and of
no color adjustment works
Do they both use the same driver? (Look in the device settings at the bottom of the page under device information in the type drop down) It may be as simple as changing the device type to the one that works.
Device Info
Also, is it possible that they aren't the same bulb models? I have in the past, gotten two different models and not realized until I installed that they were different.
