I got a couple of the Sengled (E39-G8C) Smart Light Switch during the Holiday Sales. I've paired them with Habitat and they registered as Sengled "Button Controller" type.
In the Button Controller App within Hubitat, the 2 Dimmer Buttons are not working, at least not as expected.
Both buttons have a "held" option, but for some reason, on the initial press down they are triggering a "Pushed" event, then if you continue to hold the button, it triggers the "Held" event. How do I prevent it from triggering the initial "Pushed" event if I'm trying to do the "Held" function?
I would like it set so that a single push, increases the light level by XX amount, but then holding the button gradually increases the light level..
Currently I have the "Held" state of the button set to the Action Type "Set Dimmer and Bulbs" > "Start raising/lowering dimmer" and then the dimmer selected.. But this doesn't do anything. The light level never increases nor decreases while the button is held.
How should I configure this so it achieve the intended use case?
