Finally got home and sure enough the hub didnt melt down, just red light was on. Yanked the plug, cause there was nothing else i could do and plugged it back in. Turns out it was 2 of my range hood lights going nuts. I am looking through the logs and found where it all went wrong. I just remembered I accidently turned on the hood lights manually (sengled color) because they didnt come on for whatever reason (thinking that was a 1 off blip, it happens). So if I am understanding this those Sengled bulbs caused the problem but they were specifically designed not to be repeaters so I'm a bit confused why they went nuts.
Going to change the name of the thread because the hub didn't melt, infact I think it did admirably trying to keep up with the bulbs.
So now Ive added everything back into their groups, automations, and such but the lights are still struggling. They wont respond after I removed them and readded them from scratch. Heres a sample of the log just now. What does all these debug entries mean?
dev:9612022-06-07 11:40:33.734 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:40:33.731 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:31.795 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:40:31.792 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:25.176 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:40:25.173 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:25.139 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:40:25.136 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:21.702 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:40:21.699 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:09.952 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:40:09.950 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:06.501 am infoKitchen Hood Light 2 was turned off
dev:9612022-06-07 11:40:06.498 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:04.969 am infoKitchen Hood Light 2 was turned on
dev:9612022-06-07 11:40:04.966 am debugdescMap:[raw:1BAE0100060800001001, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:40:04.799 am infoKitchen Hood Light 2 was turned off
dev:9612022-06-07 11:40:04.796 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:7802022-06-07 11:39:44.097 am infoFob Grizzly has departed
dev:2682022-06-07 11:38:46.192 am infoGroup Kitchen Lights switch is off
dev:9612022-06-07 11:38:43.460 am infoKitchen Hood Light 2 is on
dev:9612022-06-07 11:38:43.457 am debugdescMap:[raw:1BAE0100060800001001, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:38:24.570 am infoKitchen Hood Light 2 was turned on
dev:9612022-06-07 11:38:24.567 am debugdescMap:[raw:1BAE0100060800001001, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:38:24.403 am infoKitchen Hood Light 2 was turned off
dev:9612022-06-07 11:38:24.401 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:38:22.879 am infoKitchen Hood Light 2 is on
dev:9612022-06-07 11:38:22.876 am debugdescMap:[raw:1BAE0100060800001001, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:38:22.841 am infoKitchen Hood Light 2 was turned on
dev:9612022-06-07 11:38:22.838 am debugdescMap:[raw:1BAE0100060800001001, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:38:19.769 am infoKitchen Hood Light 2 was turned off
dev:9612022-06-07 11:38:19.767 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:38:18.248 am infoKitchen Hood Light 2 is on
dev:9612022-06-07 11:38:18.246 am debugdescMap:[raw:1BAE0100060800001001, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:38:11.015 am debugsetLevel(0, 0)
dev:9612022-06-07 11:38:11.012 am debugsetLevel(0)
dev:9612022-06-07 11:38:11.010 am debugoff()
dev:9622022-06-07 11:38:10.353 am debugsetLevel(0, 0)
dev:9622022-06-07 11:38:10.351 am debugsetLevel(0)
dev:9622022-06-07 11:38:10.348 am debugoff()
dev:4512022-06-07 11:38:03.479 am infoBathroom Fart Fan is off [physical]
dev:9612022-06-07 11:37:58.993 am infoKitchen Hood Light 2 was turned on
dev:9612022-06-07 11:37:58.990 am debugdescMap:[raw:1BAE0100060800001001, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:37:39.223 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:37:39.220 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:37:37.761 am infoKitchen Hood Light 2 is off
dev:9612022-06-07 11:37:37.758 am debugdescMap:[raw:1BAE0100060800001000, dni:1BAE, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:9612022-06-07 11:37:30.516 am debugsetLevel(0, 0)
dev:9612022-06-07 11:37:30.513 am debugsetLevel(0)
dev:9612022-06-07 11:37:30.511 am debugoff()
