Sengled bulbs and Linptech human presence sensor ES1
I was having a real problem with this sensor and these bulbs and a simple automation. Every time it turned off the bulbs, 20-25 second later it turned them back on. Took me a while to figure it out. I am using a C-8pro and the zigbee versions of bulbs and sensor.
In the bulb setup, under preferences, there is a command switch to "enable command retry logic." For each bulb, it was switched on. Turn that off and the bulbs STAY OFF when the device detects no presence or movement.
Ta da. Hope this helps somone.
