Is it possible to send a Configure to a ZWave device? I have glass break sensors that don't respond to Refresh command - but do respond to Configure (when I push it in the device).
The reason I ask - I am using Device Watchdog and any devices that have not checked in within 24 hours I am trying to send Refresh or other commands to get them to report.
I am also having the same issue with Aeon Sirens - Refresh doesn't work. Off doesn't work. I used Set Volume and that worked - BUT for some annoying reason they occasionally BEEP for 1 second when they get that command.
You can choose any capability the device supports--anything that will make it show up to select is fine (even a borderline nothing capability like "Actuator"). Siren would certainly work, but don't worry about being too careful there in the future.
@DarellCraighead is your glass break sensor using a custom driver? If so you can just modify the code to add another capability so you can select it in RM.
