I am also running 2.2.8 on a C-4, currently 2.2.8.147.
To try and start from a simple starting point, when I try to create a rule in RM legacy I see this screen offering me the option to create new variables, do you see something similar?
The new Rule Engine when it uses Variable, it means Hub Variable NOT Global Variable, so it appears the latest update dropped access to the Global variables
Will require a lot of updating and re-writing rules
I'd like your post for having solved the mystery, but hopefully your option for re-writing isn't entirely correct... Probably worth searching for others that have tackled that since the relese. My understanding is you should still be able to access / create legacy rules, can you can not do that, or have you converted the rule(s) you care about to RM5?
Re-write because I use variables to store messages etc -
Quite correct don't have to rewrite if I keep everything in the Legacy including new Rules, Having the same Variables defined in Global AND Hub will lead to confusion and will be a nightmare to synchronise.
I need to think how I am going to have to migrate all variables and all the Legacy Rules that use them across to Hub Variables and rewrite rules.
It makes sense to use Hub Vars going forward, I just need to spend some time working out how to do it all.
Sounds like a process for transitioning would be useful, if one hasn't been written yet... Perhaps someone has posted there approach... If not, you might pave the way for others....
I use Global Variables for tracking heating demand in every room of the house, changing to Hub Variables should speed it up and reduce CPU loading, so the right thing to do.
I also use Global Variables for standardised Heating Alerts, Security Alerts, etc etc to push out messages to the right devices, so I don't have to add that to everything that needs to send out a message.
Not a problem , will just need to re-think the v4 version of the Heating System I have been working on.
