Schlage locks
Hello, I just started setting up my new hubitat (very new user). I will probably be posting a lot of questions.
Iโ€™m curious about Schlage Sense locks. I have two locks that I would like to add into hubitat are however I am not finding the answers I need with the bit of research I have done. How would I add in my Schlage Sense locks with the Schlage hub I have with it?
Welcome to the community!
Hate to be the bearer of bad news, but you probably wonโ€™t be able to.
https://docs.hubitat.com/index.php?title=List_of_Compatible_Devices
I am unaware of a user written driver, either.
You might be able to do this but the way is a bit circuitous.. If you use Apple stuff like AppleTV or HomePodMini you may be able to connect the Schlage to that. You would then need to set up something called "HomeBridge" and connect the Hubitat to that using one of the community Homebridge Apps. You would create a virtual switch in HE and expose it to HomeKit via Homebridge then have an Apple Homekit automation to flip the switch when it is unlocked/locked.
This is probably the "simplest" way to do it short of writing your own driver/app if the API is even accessible..
:frowning:
