Schlage door lock
My Schlage door lock is discovered but will not initialize, before update it worked fine. After update I had to re-include all of my devices and rebuild dashboards (my fault because I did not back up). I reset lock to factory default but unable to get Hubitat to initialize after device discovery? Any suggestions?
Ed
How far away is the Schlage lock from the HE hub? The Schlage locks go into low power mode when in including/excluding (presumably for security reasons). The result is you need to include/exclude when the lock is ideally foot or less distance from the hub. Every time I tried to do that several feet away I had the same issue as you.
