I've had 3 of these locks since 2013 from the Original ST days. Now I'm here at Hubitat. I could ONLY get the 2 succesfully paired. The 3rd lock, I could only get status Locked or Unlocked. No mechanical control.
These locks are the Old Zwave tech. I called Schlage they advised they are not discontinuing the Zwave protocol. It's just a shortage of parts (chip) in getting these locks produced. So I bit the bullet...found and purchased a Zwave Plus version of the Zwave lock.. All I have to do is switch out the core from the B/O lock.
Just thought I would share with you folks that are still rocking the Schlage Locks. I have all mine keyed the same....so luckily/hopefully I can just swap the cores...
Home depot will rekey those for free. That said 2 things need to be considered with the older be469's (as well as the new) Firmware needs to be 7.10 or above and they should be paired within 2 feet of the hub due to the whisper security exchange the lock needs to do with the hub..
Yep, all you have to is swap out the plastic-encased electronics module. Only tricky part is that, during reassembly, start with the L-shaped key, from the keypad to the lock, horizontal with the bolt retracted.
I swapped out the electronics on my two BE469NX locks (using modules / for parts locks obtained on eBay) when I got my C-7, making them BE469ZP, so as to get S2 pairing. They continue to work fine on my C-8. Battery life went from about 6 weeks to over 6 months when I changed to S2 pairing, which is why I did it (and my reason for getting the C-7).
Would you happen to know if the Zwave transmitter itself is located in the the Body where the batteries are located in the back of the door?
I wouldnt think the Zwave transmitter is located in the Keypad part.
I just had a thought where i can reuse my existing Keypad with the original core intact (without disassembling) i just have to use the new Body / Battery Compartment part which sits on the Backside of the door
Thankyou that worked. Soo forgetful and confusing sometimes
So i had to access Hubitat Hub
Go into amazon echo skill
Select 3 doorlocks
Update
Then my alex app sees the locks and adds
Beware...don't give your address to @rlithgow1 or he'll start doing drive-bys shouting "ALEXA, OPEN THE FRONT DOOR LOCK" at your house at 3 in the morning.
