I cant enter more than 4 digits either in the driver or via lock manager.. Using the generic zigbee lock driver.
Anyone else have this issue?
Did you set the code length on the lock? You have to do this using the programming instructions in the manual, then you can run the "Set Code Length" command on the driver to match. (Contrary to what the name might make you think, this is just a command for the driver since it can't read or set that information on the device.)
Any idea how to do that its not shown in my instructions i got
Thanks worked great
