None of my scheduled events, rules, etc are working. After first noting that scheduled simple/basic rules were working I then noticed that anything that is scheduled is not working.
I found this in the hub events log:
@support_team can you help?
I initially posted this:
Since I thought the problem was only with my automation rules...
I would try a reboot with database rebuild.
If you're unsure, this is under advanced settings when you hit the reboot button.
I already tried the database rebuild option - same error in the log at startup...
Try restoring an older database.
I'll give that a try. I see now that my weekly scheduled backups stopped after 1-17-2026.
That looks like it did the trick! THANK YOU
