Just looking to see if you could add a more graphical setup for scenes. Kind of like ST. Have a color palette to choose colors? Thank you.
See ST setup photos:
You mean specifically the color picker? The one used in HE doesn't work all that well to begin with anyway. Would be a little tough given HE's method for creating scenes. You have to first add the devices and then capture the status of the connected devices. Also, you can manually "recapture" a scene later. So, if you are creating a scene, you can use the color picker in the edit device page to pick the color for the devices you are going to add to the scene. Having the color picker for each device in the adjust scenes window would be excessive to the UI IMHO.
It would be nice to have the color palette picker.
For each bulb in the scene? I disagree. I think it's overkill for the UI. Scenes are supposed to be things that you set once and don't muck with all the time. Have the lights at the settings your want when you build the scene and all the colors will be captured. No need to pick from a palette.
I just thought it would be easier to figure out the color you would want using Hue or other Color Bulbs.
What I'm saying is that the color picker is available in the edit device page. So, go there, pick you color. Then go over and create your scene. Scenes in HE are not like "scenes" in the hue app. They're meant to be static or controlled by a virtual capture device. You're not meant to be tweeking them all the time. I just think that would put a lot of unnecessary stuff on the UI. If you have 10 bulbs in a scene, you'd need 10 of them. That's excessive.
Sounds good. Thanks for responding..
