Scene stop rule then continue
Is it possible to have a scene pause a rule then continue that rule when the scene is turned off? For example, from Sunrise to 10:30pm I have a motion lighting rule that turns on the master bath lights to 100%. What I would like to do is have a virtual switch activate a scene that would pause that motion lighting rule so the motion detector wouldn't turn it on, and then when the scene is turned off that it resumes functioning. As usual I feel like I'm making this more complicated than it should be.
Each scene has a scene activator which is basically a switch.
You can add a predicate to the rule that the scene activator be turned off.
I think this covers what you are trying to achieve.
Will give it a whirl! Thanks!
