Samsung Microwave Driver for HubiThings
On the todo next list. The .11 release had a lot of virtual stuff I wanted to finish.
OK, understood, BIG Thank You and sure. no problem.
Hey, thanks for putting this together. Any idea if it will work with the Samsung Bespoke Range hood? Thanks!
https://www.amazon.com/gp/product/B0CFDF5N97/ref=ewc_pr_img_1?smid=ATVPDKIKX0DER&th=1
It might/should since it appears to talk to ST and would be available in the API. Samsung appliances are a little hit/miss following the specifications. For example the HAVC uses non-documented calls to turn off/on the light. I don't see anything in the ST forum so my advice is face value here.
Did you ever get a chance to finish the Microwave main? I have the hood functions working, but nothing for the main microwave appears, just shows the same hood functions.
