I am a Newb and I just got all of my devices set up. I can say that I have had a very good experience so far and this community has been incredible.
I ran across an issue with my new Aqara P1 Motion Sensor RTCGQ14LM. The device in the bathroom has worked perfect since minute one. The one at the back door has not. Here is the statuses on both:
Back Door Sensor
Current States
motion : inactive
powerSource : ?
Bathroom Sensor
Current States
battery : 100
batteryVoltage : 3.192
illuminance : 39
motion : inactive
powerSource : battery
temperature : 77
This is a zigbee device which is new for me as I have mostly always used Z-Wave.
Is there a way to do that without removing it. The way the thing is made it uses double sided tape which is stuck to my wall and to the bottom of the device. If I take it down, I will need to remove the tape and put new on. Not too big of a deal but I am old and don't like to get on the ladder. The device is very close to the hub.
Just try several times then. Persist, until the Current states are populated with all attributes,
Keep pressing shortly the pair button on the device during the Zigbee discovery process.
Slightly off-topic - I have begun using 3M Command Strips rather than the double sided tape when mounting devices such as this. It makes it easier to remove them for things like battery changing . . .
Before, I was able to pair the Aqara P1 sensor far away from the hub while developing the driver.
Later, I added more Zigbee devices including two Tuya radars that send distance reports every second when activated - and as a result, I can't pair again P1 from a long distance anymore, must be 2-3 feets close to the hub.
Have you tried simply clicking the CONFIGURE button on the Hubitat device details page for the one that has not yet reported in all of its attributes? Sometimes devices also have a REFRESH command that can cause them to send their latest status reports to the hub.
Or, simply wait, and those additional attributes may just fill in on their own over time. The Aqara devices are finicky, which is why Hubitat does not list them as being fully supported.
When clicking on the 'Configure' button, you must wake up the battery-powered device at the same time. Waking up can be done by a motion near the sensor or again by a short press of the physical pair button.
