Z-Wave device id: 25 failed S2 bootstrapping - KEX_FAIL_KEX_KEY: Key failure indicating that no match exists between requested/granted keys in the network. - the device needs to be excluded then included
Not really an error...just something that happens when you add a S2 capable device w/out S2...or is it actually a real problem?
Correct, except on my 55" TV, which I use as a NUC monitor, things cut off just below the countdown unless I remember to scroll. By then I'm so nervous about whether I have tapped the Inclusion sequence correctly, I spazz.
No…I get the option to add without security and select that. This message shows in my log for almost every device I’ve added.
I’m am never prompted for the DSK.
Hence the concern…and It’s not just my HomeSeer switches…
I am using a 3rd party driver since the default one doesn’t let you control the annoying default 3 second ramp rate. No idea yet if things like that matter.
Could be something with those devices trying S2 anyway, as long as they paired and work it’s fine. Those logs might be normal I have not paired anything in a while.
I am one of the pro-S2 people. I use S2 on any device that supports it with both HE and ST.
Biggest plus for me is that S2 enables full CRC checksums on all data. Without S2, only 100kbs links use CRCs. To me that solved the random errant sensor data or switch doing something weird.
One con is that updating firmware with S2 can be slow(er) or tricky to do. The built in zwave firmware update app still doesn't work with S2 devices (no warning either, it just doesn't work) so you need to use another method. I usually update firmware using PC controller as a workaround.
I don't care about the actual "security" (ie encryption) aspects of S2. The increased reliability of message transfer is worth it to me.
Agree with everything @coreystup said... Firmware updates were the one thing that previously held me back with S2, since I'm a Mac guy at home and I simply have no appetite for jumping through the hoops of getting a z-stick set up (I know it's not rocket surgery, but it's more hassle than I want to deal with).
If you don't have or don't want to use a z-stick, these steps work for GBL and OTA files (which cover Zooz, Leviton, and Aeotec). Admittedly, these steps aren't as convenient as the built-in updater, but they work well.
It is very common on Zwave 700, may even be a requirement for certification. I believe it started with Zwave 500 devices, and some of them do have the QR code but far from most.
I will have to try this out. I removed my Zen25 as i have had occasional issue with a specific zwave device not responding after a while. I thought it may be related to the Zen25, but it still happens.
The issue with the firmware updates is a known one. I think the It is recommended to exclude and re-include the device without security for firmware updates. The documentation from Zooz for instance always suggests this procedure after a firmware update.
"Currently, Hubitat's built-in ZW updater tool doesn't work with S2-paired devices."
Can someone please confirm that since I'm NOT connected with S2 currently, I should be able to update and firmware I want first, exclude everything, and the add them back in S2? IE - If they are not connected S2 it's fine.
I have run the upgrade already one of my 300 series Homeseer dimmers and it
seemed fine.
Yes the firmware updater works for no security devices. On S2 it gets to the very end and then fails but the device rejects it so no harm is done. There is an older driver based updater which does work on S2 devices.
@mavrrick58 on the Zen25 I am working on a driver for it, mainly for Zen20 people but testing it on my Zen25. It’s almost fully functional at this point.
