Does anyone know how to connect Hubitat with Russound? I have the Russound MCA-66 and the MBX-Pre and would love to be able to connect it with Hubitat.
Any help would be appreciated. Thank you.
Itβs probably possible, but not necessarily a simple thing to do. See this thread, for example:
Is their rs232 implemented over telnet? I built a rs232 driver using telnet for the Optoma projectors. It is marked as only working with the UHD51A but I'm fairly certain it works with most of the Optoma projectors.
Anyway, if they implemented rs232 over telnet in a similar way this driver will get you most of the way there. You can use it as a template and change the rs232 commands.
