I'm trying to sense when a device has stopped responding. I planned on using runEvery1Minute(someMethod). I am using a state variable that is reset in the parse method.
I thought the best way to initialize this method was to put it into the "def installed" method of the DH. However "def installed" doesn't seem to run. Even if I change the device handler from what it is to "device" then back, def installed log.debug statement is not run based on monitoring the live log.
I though def installed when the DH is assigned to a device (and saved) perhaps I'm wrong.
When does "def installed" run?
Where should I put the runEvery1Minute(someMethod)?
I read an earlier post that suggest that I may have to go to 5 minutes but as of now I can't get the method to run at all.
thanks
John
