I believe this is the first new rule I’ve tried to create since my Hubitat was updated with RM4. I’m trying to define a motion-triggered lighting rule that’s similar to some of my existing rules. The steps I took:
In the Rule Machine, select “New Rule”
Enter the rule name
“Select Trigger Events”
Select “Motion”
Select the appropriate motion sensor
“Update”
“Done with this Trigger Event”
“Done with Trigger Events”
“Select Actions to Run”
Select “Conditional Actions”
Select “IF (conditions) THEN”
Define “New Condition”
Select “Mode”
Select the modes when the rule should apply
“Done with this Condition”
“AND”
“New Condition”
Select “Switches”
Select the appropriate set of lights
“Update”
Turn on “All of these?”
Switch is “off”
“Done with this condition”
“AND”
“New Condition”
Select “Lock”
Select the (virtual) light lock
“Update”
Lock state “unlocked”
“Done with Conditional Action”
Select “Activate Scenes”
Select “Activate scenes per mode”
Select the modes (same as used in the conditions)
Click out of the mode selection list
At this point all fields on the form are locked, and there’s a spinner in the top right corner that keeps spinning indefinitely.
I’ve tried re-loading this page, and that just shows a box that reads “ Please wait, loading app Rule-4.0 ...” with a larger spinner underneath it, which also hangs indefinitely.
Forgot to mention: my Hubitat is “Currently running version: 2.2.3.135”. I’ll try updating that to 2.2.3.145 later today, but I don’t see anything in the release notes which relates to this issue.
Is there possibly an issue with the scene you selected? I'd check it again and make sure all the devices are valid in the scene and something didn't drop off or get deleted and still persists in the scene.
Looks like it isn't picking up your scenes for whatever reason. Maybe try reinstalling your scenes app and recreate the scene just to make sure it isn't something in there hosing it up. Especially since two people have now went through your steps without issues.
I don’t see how, but apparently that did the trick! I went to create the rule again and this time, after selecting the modes, it showed the available scenes. The Rule-4.0 rule has successfully been created.
Thank you.
I will see if I can force that situation to occur (it shouldn't). Every time you create a Scene, it registers itself with the parent app. And every time you hit Done in the parent app, it refreshes that list. Both of those events republish the list. Maybe there's a hole somewhere on the RM side, expecting a list that isn't there.
