Having a problem with this rule, and hoping someone can enlighten me.
I want my garage lights to come on and stay on as long as the garage door is open. I also want my garage lights to come on and stay on as long as I am moving around in the garage, even if the garage door is closed.
Typically, I go into the garage and the motion sensor makes the lights come on (good so far). Then I frequently open the garage door, and the lights stay on for as long as the garage door is open (good so far). However, when I go into the garage and don't open the garage door, the garage lights come on immediately, and then go out after a few minutes, even though I am moving around. I then dance in front of the motion sensor and the lights still do not come on. The motion sensor is an Ecolink and it has a 4 minute reset interval. There is no HE Motion App instance tied to this particular motion sensor.
I thought that if I was active in the garage, the motion sensor would keep triggering the Rule and cancel the previous command to turn off the lights. Is that not true?
