One of my rules have been stuck in a false Boolean. It never turned back to true.
Is there a way to force it back to true ?
What do you mean "stuck" in the false boolean? It will stay in False until a rule sets it back to True. You can write a simple action setting it to true and then run it via the button. Can you show a screenshot of the rule that failed to set the boolean back to True?
Thanks. That did it.
I’m pretty sure I know what happened. When that rule triggered I went into and modified it before the Boolean was set back to true.
I’ve had this rule running fine for over a month.
