Rule staus in condiotional actions
@bravenel I am adding a rule to use button 3 of a pico remote to pause an automatic light rule for a bathroom. My goal is on hold of button 3, the rule is paused and goes to manual control for 2 hours. I noticed that while constructing the If-Then conditional action, when I choose a rule status (paused or running) for the If part, that once all selections are made, it then shows in the rule as IF (any paused), instead of having the name of the rule in the conditional. It does list the name of the rule in the actions to run. Screen shot of rule -
Thanks, will look into that bug. It's most likely a UI bug.
Update: Found the cause, a UI problem. Fixed, for next release.
