If that's true @bravenel will need to look at it.
I can replicate easily
But I have an assumption that the All of these Option changed the Condition from One of These to ALL of These
But not the case ANY use of the All of these OPTION turns the Condition to FALSE
Please provide some evidence of this. For instance, grab screenshots of the device events to show that they are all idle. Ideally, reduce your test to just two devices. I may create a small test app for you to use if you can demonstrate this. This could be a driver issue. Rule is looking for device.currentThermostatOperatingState from the driver.
Worked around it and created an IF THEN with ANDs between them all
If I use ANDs it shows TRUE
If I use All of these it shows FALSE
Consistently
even with the two devices - shown above in thread
I'll test with something easier and see if it is consistently wrong
I think this demonstrates the issue
According to this Rule with 'All of these' enabled then The Bathroom or the Guest Ensuite are NOT IDLE
But the Devices say different
And just to verify
Tested same states with same Thermostat Controllers USING AND and not the All option
and get a different result
Thanks. I will post here soon a small test app for me to tell which is the source of the error.
Please install this, select the thermostats, and hit Done. Post the logs it outputs.
definition(
namespace: "hubitat",
author: "Bruce Ravenel",
description: "Rule",
category: "Convenience",
iconUrl: "",
iconX2Url: ""
preferences {
section {
input "therms", "capability.thermostat", title: "Select thermostats", multiple: true
def updated() {
def installed() {
log.debug "current therm state = ${therms.currentThermostatOperatingState}"
Nevermind the little app. I can reproduce the bug you've found.
Interestingly, other multi-thermostat tests with all work:
No problem
Good
It was doing my head in
Found the bug. The code has a misspelling:
compare(it.currentThermmostatOperatingState, "="
Fix will be in next release.
Ha
Awesome thank you.
I am new to HE - how often do you do new releases?
It's been running a two to three months lately.
You're the first person who's ever used all for thermostat operating state with multiple thermostats. This bug dates back to the very beginning.
Ha go figure!!
I have got the heating system working nicely now.
With 9 radiators, will keep it stable for the week then add the rest.
Thanks for jumping on this !!
Mike
