@bravenel I was playing around with variables and variable math. Deleted the variable and the rule. Now when I click Rule Machine I get this error.
LOG ENTRY [app:7](https://192.168.x.x/logs#app7)2020-01-13 09:15:05.924 pm [error](https://192.168.x.x/installedapp/configure/7)java.text.ParseException: Unparseable date: "12:18:00.000" on line 340 (mainPage)
That fixed my issue with RM. My wife would like to submit a list of my other issues to see if your abilities are as miraculous as I just joyfully announced to my family.
Sorry to revive an old thread - this was the closest to the issue I’m seeing. I upgraded my hub to 2.3.0.112 yesterday and I’m now getting this unparsable date error.
First thing to try would be to upgrade to .113 IIRC there may be a fix in it for this. If that doesn’t work try entering the parent app and clicking done.
Thank you - I see that there is a new version available now. I just updated to it - but still have the same problem.
It is a rule 4.1.
I’m not sure what you mean “entering the parent app”. Enter Rule Machine Legacy? I tried that, clicked done, but it didn’t help.
I’d be happy to rewrite this as a new rule (if it’s the legacy rule set causing this) - but I don’t have the old code and I did this long ago and don’t remember what I did. Is there a way to see the code? I have plenty of backup files.
I'm running 2.3.0.124 and seem to be getting this same unparsable date error when setting up a rule with just times either through Basic Rules or Rules Machine. Has this issue started again in the latest version or is there something else I need to try here?
@bravenel This is the rule, i'm trying to setup a rule to only run between a certain time (7am to 11pm), but when I add the condition I get the "Error: Unparseable date: "07:00:00"" error. This is a Basic Rule, but same things happens with Rule Machine rules.
What platform build are you on? Also, please show the main setup page for the rule. It would also be helpful if you could show a screenshot of the logs. Same for the Rule Machine rule.
@bravenel I'm running 2.3.0.124 on Rev C-7 Hardware.
Everything is fine on the rule until I click "Add optional restrictions that limit when this rule runs" and then select "Only between two times" and then set 2 specific times.
This is certainly odd. I am not able to reproduce these errors. Your first screenshot of the Basic Rule does not show the restriction in place. So that's confusing. What browser is this? The Basic Rule time picker (and RM), at least in Chrome, Firefox and Safari, does not offer a seconds field, and the app is not expecting seconds. This is most likely the cause of the error.
I'm on the same version of Chrome (different Mac, OS 12.0.1).
I've never seen this before, and it's something caused by the string being returned from the browser. Remove the rule, and recreate it with Safari. See if that throws this error or not.
