Rule Machine Trigger Not Working
I have a very simple rule to turn off a light at a certain time. Worked great until about a week ago and seems to no longer Trigger at the time. Thoughts?
Have you recently changed in/out of daylight savings time? People have been experiencing some issues with that recently.
Otherwise, it may pay to quote the platform version you are running and paste either a screenshot or text description of the different elements of your rule.
Yes last Sunday was time change.
I would suggest looking over some of the recent threads on this, I can't remember where it got to for others experiencing these issues. I'll see if I can find some of them later if you don't have any luck
It's always good to post a screenshot of the rule if you can.
Maybe look at past logs to see if anything shows up.
Try turning logging on for the rule and see what shows up.
Opening the rule and clicking done can sometimes reset the rule. :crossed_fingers:
There are some threads that talk about similar issues, but nothing that I can point to specifically that resolves your issue. In the end I expect if you save your rule again it may work.... but I can't be sure about that. Hopefully HE staff can assist if this continues to be a problem for you.
I have opened the rule, clicked done and rebuilt the rule with different actions and nothing worked. I believe the time change has caused an issues with HE.
  • I tried to upload several different images but I get an error that they are not allowed.
That happens when you first register and post on the forum. It should start allowing you to post at some point soon. You might need to go through the @discobot tutorial.
Have you tried stopping the rule, and then re-starting it?
Hi! To find out what I can do, say @discobot display help.
As a stopgap, you can create a link to your screenshot image(s) and post the link(s) here in your reply. Google Photos makes doing so quite simple.
Same with me as well. I have a simple rule with Echo Speaks, to send speach notification to an alexa device, and notification to my phone via the hubitat app. Test via "run actions" doesn't work. However, running rules via legacy rule machine, does work.
Yes I have also rebuilt the Rules. HE is not firing Certain Time rules. Anyone else using Certain Time rules and are they working?
Are you now able to post a screenshot of your rule by any chance?
No I still get the error.
Give it a try again - is should work now.
Much better thanks.
Thanks for the screenshot! I see you have logging enabled. Can you share two more screenshots? One of the logging for that rule, and another of the Ā« Scheduled Jobs Ā» sections of the screen that comes up when you click on the ruleā€™s gear icon (top right).
It is a very simple rule and should workā€¦ There was an issue with timed events on the day of daylight saving change, but as far as I know, they should work properly again on other days.
There is nothing in the Logs for this rule as it seems to never fire.
That would make sense. Though it is now scheduled to fire at 10PM PST today.
I would be curious to see if you change the time to sometimes in the next few minutes, would the Scheduled Jobs update and would it fire? (Shouldnā€™t based on what you are seeing, but never know!). Can you post a new screenshot of the Scheduled Jobs after you changed it and then after the time has passed and it didnā€™t trigger?
