Just installed RM on C-7 hub. Added RM from built in apps.
When I try to use it I get an " Error 404
App type with namespace: hubitat and name: Rule-5.1 has parent type that does not match current app"
I see lots of the same in forum but no answers.. I don't know how to proceed.
Any help would be appreciated.
What platform version are you running? Check Settings > Hub Details.
Also:
- try waiting a few minutes (maybe 10 or so) to see if the problem goes away on its own; or
- try a Settings > Reboot and see if that helps (without without waiting again after)
Thanks for the reply,
Platform Version is 2.3.9.166
I've rebooted and removed it and re installed it.
it does start but when I click create new rule if fails.
Jim
Could you please send me a private message along with your hub id?
I am experiencing the same as above on a C-7 hub with platform version 2.3.9.177.
Could you please try the following:
- Bring up http://hubs.ip.address.here/app/appTypeList page.
- Find ruleApp51, click Delete link. It should show up an empty page.
- Reboot the hub.
* replace"hubs.ip.address.here" with your hub's IP address
Hello bobbyD. Thank you for the reply.
I noticed today that platform version 2.3.9.180 was available for my hub. After the update, I was able to create and run a new rule with Rule Machine.
Following your link, ruleApp51 is listed with "1" for Instances and has no Delete link.
