I am trying to setup this rule to a bulb but can't seem to find a simple way to flash a bulb. I need to setup another rule just to flash a bulb and run on truth?
If
Mode : away
Motion : active
Action for True
With bulb 1
Setlevel : 80
Color : red
Flash : every 3 seconds
If I was at home I'd screenshot, but if you go to rule machine, there is create new rule, trigger, and then below that is custom command. After you select custom command, it will have you select a device and then the commands that device supports.
Once you save your custom command, you can use it on rules.
This is not quite what I am looking for because bulb driver doesn't support flash so it won't work with custom command.
How about just on/off every 2 seconds?
I am having the same problem. I am trying to create a rule that will throw itself into a loop using delayed actions. I am using a virtual switch to control it, even still I am always weary of loosing control of a loop.
Not so simple for me since my mode is away and motion active. I have to create another rule to monitor motion inactive and turn off virtual switch. Total 3 rules. I guess I will stick with webcore for now. Thanks for the option.
None of my lights/switches/outlets support flash and I wanted to use the flash lights feature of HSM. So I created a rule to flash specific lights, tested it, and it works great.
Hope this helps someone else, the key is to repeat action and to select toggle lights.
PERFECT!! the only way to flash my lights to confirm if they gone automatic or not as I wanted. Only one thing to add:
If you use the same light to confirm/flash and you want to keep it in the state before flash just give a pair number of toggle (2, 4...)
Hi bravenel I understood Update 2.09 is released but my hub still on 2.0.8.113 and when I hit Update is saying "No updates available". Do I missunderstood this?
