Hi, I need your help !
I have a rule to auto close my garage door. The issue is that If the door is manually closed before the end of the 1 minute delay then the rule reopens the door, triggering the autoclose rule, It waits for one more minute and finally close the door. Not so bad, but winter is coming .... in Canada !
Is there a way to create a rule that is canceled by the close contact sensor so the door doesn't reopen If manually closed ?
I have a contact sensor on the door and a relay (temporary switch) is activated to open/close the door.
Thanks !
