Rule Machine for outside lights?
If you can get rule machine to turn the bulbs orange, then it’s fairly straightforward. The trigger would just be time of day. You would then use a required expression of October 31 and it will run on that date every year.
With the above said, I’d recommend looking at [Release] Holiday Lighting if you are thinking about multiple different holidays.
