@bravenel
Maybe not a bug, but inconvenient:
When doing a simple conditional action, using a custom command and a global variable as the parameter - if you enter the global variable wrong (bad value) or the wrong global variable, there doesn't seem to be a way to edit it. You have to delete the action and start again.
